HOW TO TST RTC1 ?
? HOW TO TST RTC1 ?
22.Apr.20 14:02
20
Matthieu Testa (F)
Articles: 5
Count of Thanks: 19
Hi, anyone able to tell me how to test RTC1 tube ?
Regards
HOW TO TST RTC1 ?
22.Apr.20 15:57
20 von 1379
Emilio Ciardiello (I)
Articles: 526
Count of Thanks: 25
Emilio Ciardiello
A simple continuity check can be done measuring the cold resistance between pins 2 and 3 - the two smaller pins - which could measure somewhere around 200 to 500 ohms. A more accurate test could be made applying 50 V rms between the same pins and measuring the current which should be around 300 mA AC. The test could aldo be done in DC.
Emilio
HOW TO TST RTC1 ?
23.Apr.20 00:26
59 von 1379
Patrice Zeissloff (F)
Articles: 16
Count of Thanks: 22
Patrice Zeissloff
Hello,
I have check my used RTC1 as in the circuit diagram of the Lemouzy TC54 radio
"Resistor" A  approx. 30 ohms cold is for approx. 110 V network with 5 tubes, eg 3 x 6.3V + 2 x 25V heating and 0,3 A heating current
V secteur I (A) V filament V (RTC1)
80 0,21 50             30
90 0,23 55             35
100 0,25 60             40
110 0,27 65             45
120 0,29 70             50
130 0,31 74             56
"Resistor" B  approx. 19 ohms cold,
For 220V network the two resitor A + Bare serial switched with  5 tubes, eg 3 x 6.3V + 2 x 25V heating.
100 0,18 43             57
110 0,19 47             63
120 0,21 50             70
130 0,22 53             77
140 0,23 55             85
150 0,25 58             92
180 0,28 60          120
200 0,3 78          122
220 0,32 76          144
240 0,34 80          160
Note : In the Lemouzy TC54 a 70 ohms are used with "Resistor" A for 130 V Network and or with A + B for 240V network.
Kind regards
