klein: FS5B; Fernseh-Service-Sender
06.Jan.04 21:02
2185
Georges Van Campenhout † 28.4.22 (B)
Articles: 202
Count of Thanks: 20
The FS5B (B = "for Belgium")  set contains in total 12 tubes: EZ81, 150C2, six ECC81, two ECC82 and two ECH 81.
Power supply is 240V, 220V, 125V or 110V
The dimensions are
  • width: 395 mm
  • height: 240 mm
  • depth: 220 mm
Serial number of my set is 10-1490
It has a big rotary switch for selecting the 11 TV channels, plus a 12th channel, that seems to be a special one.(FM range?)
Also image 3 IF ranges:
  • from 16 to 21 MHz
  • from 21 to 29 MHz
  • from 29 to 45 MHz
and a 5.5 MHz range, FM modulated, from 5.2 to 7.2 MHz, als probably as harmonics fram 10.4 till 14 MHz, which is the FM IF range.
