korting: 1007W (1007); dial lamp reflector?
? korting: 1007W (1007); dial lamp reflector?
01.Apr.10 08:10
Thomas Albrecht (USA)
Officer
Articles: 378
Count of Thanks: 5
Thomas Albrecht
Radio friends,
I'm servicing a Körting 1007 for someone.  The radio is now working very well, but the dial lighting is very poor.  The dial lamp is mounted on top of the chassis, a bit behind the dial, without any direct light path to most of the dial.
Did this radio originally have some kind of reflective shroud to chanel the light into the dial area?  Or is this simply a poor design that always has very dim lighting of the dial?
As it is now, the upper red pointer is barely visible, and the lower green pointer is virtually impossible to see.
Tom
P.S.:  On a different subject, the original type EM85 eye tube seems to be impossible to find, but I'm having good results with an EM81/6DA5 with the socket rewired.
This thread was moved automatically.
This question was moved automatically to the board "Talk" to get more possibilities for answers.
Moved from board »RADIO MODELS DISPLAYED« on 07.Apr.10 08:10 from automatically
Home-made reflector
08.Jul.10 04:28
131 von 3459
Officer
Articles: 378
Count of Thanks: 16
Thomas Albrecht
I was able to make a suitable reflector out of white paper taped in place.  This greatly improved the visibility of the dial pointers.
Not clear whether this radio originally had some kind of similar reflector originally, but it must have, since otherwise there is no direct path from the dial light to most of the dial.
Tom
Moved from board »* TALK - visible for members only« on 08.Jul.10 04:29 from Thomas Albrecht
