unknown: Likely Rochefort
Dieser Artikel betrifft das Modell: unknown Spark Transmitter (Unknown to us - Worldwide)
20.Nov.22 14:24
2205
Nikolaus Löwe (D)
Nikolaus Löwe
Dear fellow Wireless enthusiasts!
Since this little transmitter has been brought to my attention, I couldn't help but wonder who built it.
The workmanship looks quite excellent, materials are good (heavy brass, ebonite, stone base), too good for a toy set. But it is obviously not suitable for long-range communication, judging from the tiny interruptor on top.
It has been sugested this might be a demonstration set. But from which maker, and demonstrating which system of wireless telegraphy?
In the Elektrotechnische Zeitschrift (ETZ), No. 45 from Nov. 1904, there is a report on the French system of wireless telegraphhy by Rochefort. The transmitter instantly reminded me of this set.
This is a commercial type of equipment. It's an untuned Marconi transmitter. There is a separate mercury interruptor U, kept in constant operation by battery B2. The optimum number of interruptions is said to 24 to 30 per second. The key T with platinum tip and mercury contact closes the circuit from battery B1 (24V 100Ah) through the interruptor with condenser C in parallel, to induction coil J. The spark gap terminals are 2cm in diameter. A spark of 5 to 10mm length is employed.
The receiver looks as follows:
A very basic coherer receiver and tapper with separate relay of 1000 Ohms, and morse inker. No tuned circuits are to be found beside the antenna, no chokes or polarizing cells to suppress the effects of the local relay contact spark.
But wait, the coherer is special. Rochefort designed a magnetically adjustable coherer.
Two short segments of iron tubing are included inside the glass tube. They are traversed but not contacted by a piece of copper wire, which is connected to the second coherer terminal. The space in between the pole pieces is filled with soft iron filings. In the receiver assembly, there is a magnet placed above the coherer, which aids in adjusting coherer sensitivity.
The system Rochefort was demonstrated to the k.u.k Austrian Navy in 1902. The receiver assoioated with the equipment is illustrated in Sifferlinger's "Auslaufen verspricht Erfolg" (2000). The adjustable magnet can be seen top left.
The Rochefort equipment was reported to be working reliably over a range of 40km and more.
In the 1904 article from ETZ (above) there is information that Rochefort had by then used a tuned circuit after Oudin (effectively a Braun closed circuit) on the transmitter end, which was not yet used during the Austrian trials.
After extensive tests, the equipment by AEG/Slaby - Arco and Braun/Siemens & Halske was introduced into the Austrian Navy.
Marconi would have been a contender, but the Marconi company was reluctant to actually sell their apparatus, as their business model revolved around leasing apparatus and collecting regular fees.
From what information I have gathered, I suppose the upright spark transmitter in question is a Rochefort demonstration set.
Yours,
Nikolaus Löwe
