Limpieza y reparacion tandem (condensador variable)
? Limpieza y reparacion tandem (condensador variable)
12.Oct.24 18:53
36
Juan Vicente Ramírez Picon (E)
Artículos: 5
Agradecimientos totales: 4
En el proceso de restauración de una Mastertone, al realizar la limpieza del condensador variable, creo que he usaso algún desengrasante o lavamanos muy fuerte y a perdido toda la propiedad capacitiva. No se si tiene solución, alguien podria ayudarme con alguna solución o lo tiro como chatarra, gracias.
In the process of restoring a Mastertone, when cleaning the variable capacitor, I think I used some very strong degreaser or detergent and lost all the capacitive property. I don't know if there is a solution, could someone help me with a solution or I will throw it away as scrap, thank you. Ich glaube, ich habe bei der Restaurierung eines Mastertones beim Reinigen des variablen Kondensators einen sehr starken Entfetter oder ein Reinigungsmittel verwendet und dabei alle kapazitiven Eigenschaften verloren. Ich weiß nicht, ob es eine Lösung gibt, könnte mir jemand bei einer Lösung helfen oder ich werde es als Schrott wegwerfen, danke.
13.Oct.24 09:09
36 from 984
Daniel Consales (D)
Artículos: 243
Agradecimientos totales: 7
Daniel Consales
Hello Mr. Ramírez Picon,
these capacitors with 3 packets are not so easy to find - so you should try to locate the problem.
At first remove all old soldering - you'll need a strong soldering iron let's say 50...100 watts because of the thick material. After that check the following:
- the rotor with the 3 moving parts and the housing have to have a very good connection. Check that with a multimeter. It should read zero ohms even if you move the rotor.
- On the other hand there should be absolutely no reading between the rotor and the stationary capacitor parts - not to the 3 different parts and those not between each other.
You said you "lost all the capacitive property" - that imho can only be a short somewhere so you have to find and remove it - I can't help with that ;-) If you measure a short on all 3 packets most likely the whole rotating assembly has been moved right or left - there must be no short in any position of the rotor.
Good luck !
D. Consales
13.Oct.24 17:40
71 from 984
Artículos: 5
Gracias por la respuesta Mr. Consales, he realizado las comprovaciones que me recomiendas y solo he observado que entre el chasis y las 3 partes fijas del condensador existe un resistencia de 7.84kΩ, que si la dejo conectada y aumenta lentamente hasta 9kΩ, y que solo me lo lee con el positivo del multimetro en el chasis, del contrario no tengo lectura.
No se si puede ser algun residuo de la limpieza que este ofreciendo esa resistencia. serguire investigando.
Vielen Dank für die Antwort, Herr Consales. Ich habe die von Ihnen empfohlenen Überprüfungen durchgeführt und nur festgestellt, dass sich zwischen dem Gehäuse und den drei festen Teilen des Kondensators ein 7,84-kΩ-Widerstand befindet steigt langsam auf bis zu 9 kΩ an und liest ihn nur mit dem Pluspol des Multimeters am Gehäuse, sonst habe ich keinen Messwert.
Ich weiß nicht, ob es Reinigungsrückstände sein könnten, die diesen Widerstand bieten. Ich werde die Ermittlungen fortsetzen.
Thank you for the response Mr. Consales, I have carried out the checks that you recommend and I have only observed that between the chassis and the 3 fixed parts of the capacitor there is a 7.84kΩ resistor, which if I leave it connected and it increases slowly up to 9kΩ, and that It only reads it with the positive of the multimeter on the chassis, otherwise I have no reading.
I don't know if it could be some residue from cleaning that is offering that resistance. I will continue investigating.
15.Oct.24 10:05
109 from 984
Artículos: 5
Agradecimientos totales: 5
Resuelto
Investigando mas profundamente, he tenido que desmontar por completo el tamden para llegar hasta el problema, al realizar la limpieza con desengransante y agua, se ve que llego hasta las fijaciones de la parte fija del condensansor, las cuales estan unidas por un unico tornillo que con sus aisladores de plastico en pricipio no debia haber problemas, pero al desmontarlo observe que existia una camara entre aisladores, el tornillo que lo atraviesa estaba oxidado y existia residuos que hacian un poco de continuidad al chasis, este era el problema, se limpian esos residuos, el oxido del tornillo y se recupera el condensador.
Resolved Investigating more deeply, I have had to completely disassemble the drum to get to the problem. When cleaning with degreaser and water, it is seen that I reached the fixings of the fixed part of the condenser, which are joined by a single screw that With its plastic insulators, in principle there should be no problems, but when disassembling it I observed that there was a chamber between the insulators, the screw that goes through it was rusty and there was residue that gave a little continuity to the chassis, this was the problem, clean those waste, the rust of the screw and the condenser is recovered.
Gelöst Bei genauerer Betrachtung musste ich die Trommel komplett zerlegen, um das Problem zu lösen. Beim Reinigen mit Entfetter und Wasser fiel auf, dass ich die Befestigungen des festen Teils des Kondensators erreicht hatte, die mit einer einzigen Schraube verbunden waren Es handelt sich um Kunststoffisolatoren, im Prinzip sollte es keine Probleme geben, aber beim Zerlegen fiel mir auf, dass sich zwischen den Isolatoren eine Kammer befand, die Schraube, die durch sie führte, rostig war und Rückstände vorhanden waren, die dem Chassis ein wenig Kontinuität verliehen, das war Beheben Sie das Problem, reinigen Sie den Abfall, der Rost der Schraube und des Kondensators wird wiederhergestellt.
15.Oct.24 10:49
111 from 984
Daniel Consales (D)
Artículos: 243
Daniel Consales
Nice you found it. Great job - congrats !
D.Consales
