metrix: 310-D ; Lampemetre
21.Jan.11 20:05
47
Stefano Crippa (I)
Count of Thanks: 8
 Hello!
I'd like to know if this tester is a mutual conductance one.
Regards
METRIX 310
22.Jan.11 07:39
47 de 4235
Christian ADAM (F)
Articles: 425
Count of Thanks: 8
Christian ADAM
Yes, it is. You need to change grid potential by 1 Volt and measure the plate current difference. It's a very robust product, well appreciated in France by collectors,
 Christian
grid shift method
22.Jan.11 11:19
66 de 4235
Kurt Schmid (D)
Articles: 61
Count of Thanks: 13
Kurt Schmid
Hi Mr. Adam,
the maoeuvre you're describing is called 'grid shift method'. This cumbersome procedure requires manual interaction and calculation of transconductance. In addition, using a large delta Ug1 (you're mentioning 1 Volt) results in an average transconductance over this grid range (problem: secant vs. tangent). Also the best German tube testers (e.g. Neuberger 370/375) are restricted to this indirect method of measuring transconductance.
In contrast mutual conductance measurement is automatic. This case the grid is modulated using a small sine wave signal of either the line frequency or a considerably higher audio frequency (e.g. 1400 Hz) of constant amplitude.
Kurt  Schmid
OK
22.Jan.11 11:35
69 de 4235
Christian ADAM (F)
Articles: 425
Count of Thanks: 9
Christian ADAM
Thanks for the accurate answer. Because I was not sure, I prefered to describe to procedure. But it's really not complicated doing this this way,
M f G from France
