national: National FB-7 versus FB-7A
15.Dec.16 14:16
2833
Wayne Childress (USA)
Articles: 4
Count of Thanks: 10
Wayne Childress
If you have Raymond Moore's book, Communications Receivers: The Vacuum Tube Era, you will find model listing for both FB-7 and FB-7A (and FBX and FBXA) receivers in the National section. He list the difference between the two as the FB-7A having air-tuned IF transformers, and the FB-7 as having mica tuned IF transformers. I have owned FB-7's in the past, and never really bothered to check whether the IF transformers were air versus mica.
While researching FB-7 coil information, I noticed that National used the nomenclature "FB-7" and "FB-7A" interchangeably.  For instance, the National Bulletin No. 220 has two pages on the "FB-7".  The first page is headed as, "National 'FB-7' Amateur Type Short Wave Receiver." However, at the bottom of the page, where the price is listed, they use the nomenclature "FB-7A" with no listing for a "FB-7." This continued in Bulletin No. 240 (1934) and No. 260 (1936).
The same thing with the National FBX-A. There is no listing for a "FBX" model.
I think where the confusion comes in is that National lists both air-tuned (XR-39A) and mica tuned (XR-39M coil forms, starting with bulletin No. 240. But the Bulletin No. 220 specifically says the FB-7 oscillator coil is "air padded."
This would not be the first mistake found in Communications Receivers. I will always have a fondness for this most useful book, but to say the book's information is 100% correct would be misleading at best. And depending on which edition (there are four) you have, the information can be way off for some models. If you read the introduction to the book, you realize that Mr. Moore was working mainly with QST magazines and ARRL handbooks. The nomenclature "FB-7" was used extensively in National advertising in 1934, as the "FB-7" was prevalent in 1934 issues of QST. So, it would be easy to see how this mistake couldd be made, if in fact, it is a mistake.
Also, it would be interesting to know what benefit that the mica or air tuned transformers have. Obviously, the mica tuned transformers would be cheaper to produce, but not at a significant reduction to make a huge difference in the cost of the receiver. And it was never National's policy to take the cheap way out. It would also appear that the air tuned transformers would perform better.
So, given that National never lists a price for a model "FB-7", but does for the "FB-7A," and their use of the nomenclature FB-7 and FB-7A to refer to the same model, can we assume that only air-tuned FB-7's exist and there has never been a "FB-7" mica tuned model?
It would be interesting to know if anyone has an FB-7 that has mica tuned IF transformers. Of course, this would require disassembly of the transformer.
