general-el: Need Help with Replacement Part
? general-el: Need Help with Replacement Part
17.Aug.20 03:23
41
Robert Stetz (USA)
Articles: 9
Count of Thanks: 5
Robert Stetz
Hello Antique Radio Experts
I am working on bringing this 1934 GE M-51 Back to life.
I have at this point cleaned the chassis and replaced deteriorated cloth wiring.
All the paper and electrolytic capacitors have also been replaced.
When I fired this old girl up she was completely soundless.  Power supplies looked good.
After a bit more investigation I found the audio output matching transformer has an open primary winding.   The speaker voice coil is good, along with the field coil.   If I could find an output transformer with 450 ohm primary and 4 ohm secondary I am sure I can bring this old girl back to life.
Suggestion on where to find a transformer or other possible work around would be helpful.
Thanks for the Help
Bobstetz@msn.com
Bob
17.Aug.20 11:49
41 de 2332
Daniel Consales (D)
Articles: 247
Count of Thanks: 6
Daniel Consales
Hello Mr. Stetz,
I just want to say that the "450" ohms are the dc resistance, According to the tube datasheet of the 41 tube you'll need an SE output transformer whith a primary impedance around 7k.
If originality is not mandatory that should not be a big deal.
If you search on google "output transformer 7k" there are many hints.
Kind regards,
D. Consales
