oskar: Oskar Clock radio: Green dial and LED display
This article refers to the model: Clock Radio (Oskar; Hong Kong)
18.Jun.21 10:53
836
And this is the more common to find version of this radio, with green color LED display and dial.
As a side note, the red color version consumes 8 Watt, while this green version consumes 5 Watt, according to the sticker labels.
Having both versions, I can confirm that the red version generates a lot more heat around the power supply components and with some overheated (discolored) resistors, while the green version seems to generate less heat not showing signs of overheated resisstors.
