Phase meter or ?
? Phase meter or ?
21.Aug.14 22:49
Moisés Piedade (P)
Articles: 13
Count of Thanks: 18
Moisés Piedade
One of my PhD students that worked for a power company, offered me an old equipment that seems to be a Phase meter or a similar thing . The dial of the instrument is graduated from 0 to 70 in each direction clockwise and counter clockwise. It seems to be graduated in degrees. Instrument was fabricated in 1903 by Con, Elec. Co  and have the serial number 1487. In top it has three terminals and the letters I and Q engraved. Instrument has four coils two for currents (small number of turns of thick wire) and two for voltages (about 400 turns of 0.12 mm wire). I don’t know for what purpose this instrument was used but seems to be a phase meter between voltage and current. The motor is a magnetized bar connected to the aiguille of the meter.   Please if you have an idea of the application of this old instrument, please let me know.
Best Regards
Moisés
Galvanometer for Telegraph
21.Aug.14 23:56
13 von 5789
Officer
Articles: 1744
Count of Thanks: 13
Most probably the shown instrument is a (differential) galvanometer for checking telegraph lines. The deflection to the right or left of the normally centered needle indicates the current direction in the wire. Also the strength of the current flow can be measured by the deflection value.
Here are two similar instruments listed in RMorg: a Siemens Galvanometer and one Galvanometer from the Swiss manufacturer Hasler.
The British Museum of Technology has some galvanometer instruments displayed and described.
Please make a new model suggestion for it, thank you.
Phase meter or?
22.Aug.14 15:40
79 von 5789
Moisés Piedade (P)
Articles: 13
Count of Thanks: 13
Moisés Piedade
Many thanks Bernhard.
Now I understand the working principle of the instrument; it has letters I and Q also engraved, like the 1930 Siemens differential galvanometer in british museum, but this was conceived in 1903. They look veri similar in pictures. I am cleaning it and repairing because one coil was broken.
Best Regards
Moises
