philips: 830B (830 B);
Cet article fait référence au modèle : 830B (Philips; Eindhoven (tubes international!); Miniwatt)
? philips: 830B (830 B);
13.Jul.10 08:56
25
Jean-Louis HEYD (F)
Articles: 28
Remerciements: 3
Bonjour,
Regardant le schéma, je ne comprends pas le rôle de la B217. Que signifie regelb. ?
Merci de vos éclairages!
JL
Pièces jointes:
B217
13.Jul.10 11:04
25 von 4568
Frédéric Delaume (F)
Articles: 71
Remerciements: 2
Frédéric Delaume
Bonjour!
Régulatrice de courant?
C'est du Néerlandé...A comparer, peut-être avec un schéma en français ou allemand.
Désolé de ne pas pouvoir vous être plus utile... Belle pièce en tout cas!
Frédéric
The basic idea...
13.Jul.10 16:21
71 von 4568
Wolfgang Holtmann (NL)
Rédacteur
Articles: 996
Remerciements: 4
Wolfgang Holtmann
Dear Jean-Louis
First accept my apologize for the reply in English!
The wording “regelb.” means in Dutch “regelbuis”, which is in English: control tube.
The function of this tube is to control the neg. bias for the final stage C243N, which is high (less anode current) with little or no LF present. This measure will increase the lifetime of the “B” Battery significantly!
In case the LF-level increases, the LF-voltage fed to the grid via C4 makes the grid at point A of B217 more negative, which will reduce the current through B217. R1 and tube B217 comprises a voltage divider. So, the average voltage at point B will rise in pos. direction accordingly!
The higher pos. potential is fed via R2 and R3 to point C, the neg. bias of C243N. Thus, the – 9V of the “C”-Battery (via R4) is altered (by more or less compensation) to a lower negative grid voltage. The anode current of the final stage returns to its normal range again.
830B
13.Jul.10 18:15
94 von 4568
Jean-Louis HEYD (F)
Articles: 28
Remerciements: 3
Hello,
Thanks for the explanations, I always discover some interesting "tricks" with the Philips batteries radio...!
Thanks,
JL
? 830B suite?
24.Jul.10 09:36
282 von 4568
Articles: 71
Remerciements: 4
Frédéric Delaume
Utilisation du B217 dans le schema du 830
24.Jul.10 11:34
298 von 4568
Jean-Louis HEYD (F)
Articles: 28
Remerciements: 3
Bonjour,
Oui, en fonction du niveau BF le tube final est plus ou moins polarisé pour économiser la batterie délivrant le courant HT.
A regarder le schema, je pense que le rôle des condensateurs est déterminant pour introduire des constantes de temps et éviter que ce régulateur agisse trop vite...
Merci,
JL
