philips: Ch= K7N; Goya SL - D26K965
? philips: Ch= K7N; Goya SL - D26K965
18.Sep.13 19:03
325
Marco Salvadeo (I)
Count of Thanks: 8
Hello to everybody. I have a Philips Goya D26K965 TV. When I purchased it, it worked fine. It was revised just before I bought it. Few days after it fault. So I opened it to see what appened and I saw that when I push the main power button to on, a spark where produced from an electronic component. I downloaded the electronic schematic from this site of a similar TV with K7N chassis to view electronic components. The corresponding component is R891 which is a NTC thermistor. The problem is that any value is specified on the schematic. So I'm asking: does anybody knows which is the value of this thermistor? Any help will be very appreciated. Thank you!!!
Thermistor
22.Apr.14 22:43
325 de 2214
Wilfried Haack (D)
Articles: 194
Count of Thanks: 7
Hello Marco, this thermistor is a special type of Philips. Somewhere (hi) I have an original type.
Regards Wilfried
Check Diodes, please
23.Apr.14 19:48
374 de 2214
Henning Oelkers (D)
Articles: 588
Count of Thanks: 4
Henning Oelkers
Hi, Marco,
If this is the NTC in series with the Main Rectifier Diodes, please make shure, to check both Diodes. They carry a very high load, and typically it starts with a faulty Diode, this causing the whole Current using the other Diode, which overloads the NTC.
Hope this helps,
BR Henning Oelkers
