philips: L1W22T (L 1 W 22 T); Nanette Versions
24.Sep.06 16:53
Marc Gianella (CH)
Articles: 307
Count of Thanks: 14
Dear colleagues
I'm working on an overview to the several Nanette versions and their characteristics. Therefore I ask you for precise data from existing devices and/or documents.
Interesting are particularly
  • Endings of the type designation L1W22T behind the /, additionally the whole remainder of the identification plate (2nd line, eventually giving the IF and production date)
  • Sequence of designations of the waverange-switch
  • FM range up to MHz?
  • Diode X1 available?
  • R24 available?
  • Transistors in the AF part (T6, T7, T8 if original)
  • The values of C11, C17, C42, C51, R24, R29, R35, R38
  • AM IF (kHz)
  • Print of the rear side of the housing (Made in ...)
Please do not post here but send answers to my email adress: marc.gianella(at)bluewin.ch
Thank you in advance for any help!
Kind regards, Marc Gianella
Edit 2007-05-06: Overview uploaded
10.Apr.07 12:59
Klaus Rohlfing (D)
Articles: 5
Count of Thanks: 11
Dear Marc,
I just got a Philips Nanette which is not working but seems to be in original condition.
First l have some interesting informations for you:
The printing on the identification label is:
A  L1W22T/82
29  460  11  65
The sequence of the waverange-switch is  U - M - L, the FM range seems to end with
104 MHz.
The AF part is made by AC 132, AC 127, AC 125 and the printing at the rear is
MADE IN HOLLAND.
I hope I could help you, please contact me for further details.
Regards
Klaus Rohlfing
philips: L1W22T (L 1 W 22 T); Nanette - details
11.Apr.07 08:19
Henryk Fidos (PL)
Articles: 15
Count of Thanks: 8
Dear Marc,
My Nanette  is not in a good condition but seems to be in original .
The text on the identification label is:
A  L1W22T/71
06  452  12  63
The sequence of the switch is  U - M - L, 88 -104 MHz.
Transistors in the AF part are: AC125 (TS6), AC127 (TS7), AC132 (TS8).
MADE IN HOLLAND at the rear side.
I will send you photos and further details later.
Regards,
Henryk
