Philips schematic capacitor notation
? Philips schematic capacitor notation
17.Sep.10 00:22
25
Dennis Wesserling (USA)
Articles: 25
Count of Thanks: 13
Dennis Wesserling
Greetings to all,
Could one of you fellow members please explain how capacitors are labeled on European schematic diagrams ?
As an example, I am currently using a diagram for a Philips BX250 B 00.  Some capacitor's values are marked as "8E2", "2K2" or "47K" - I am at a loss to understand the markings.  (I'm doing much better with resistors though....I understand their markings). Other caps marked "400" or "82", for example, are obviously noted in picofarads.......likewise, a cap marked 4uf is quite obvious also.
Is there perhaps an online chart of some sort available that would explain the system ?
Thank you in advance
Dennis Wesserling - USA
added link
Philips notation of capacitors and resistors
17.Sep.10 07:48
25 von 12472
Martin Renz (D)
Officer
Articles: 579
Count of Thanks: 11
Martin Renz
Capacitors:
1F =1 Farad
1mF=1 Millifarad
1µF=1 Microfarad
1nF=1 Nanofarad
1pF=1 Picofarad
1F=103mF=106µF=109nF=1012pF
Examples as seen on Philips and other European schematics:
8E2 = 8p2 = 8.2pF
4k7 = 4n7 = 4.7nF = 4700pF
100 = 100µ = 100µF = 100 000 000 pF (electrolytic capacitors)
100 = 100p = 100pF (ceramic, mica and variable capacitors)
Resistors:
1Ω  =1 Ohm
1kΩ =1 Kiloohm
1MΩ =1 Megaohm
1GΩ =1 Gigaohm
1 Ohm = 10-3kΩ = 10-6MΩ; = 10-9GΩ
100 = 100Ω
4k7 = 4.7k = 4.7kΩ = 4700Ω
8M2 = 8.2M = 8.2MΩ = 8 200 000Ω
More information about codes:
Colorcodes of Beyschlag resistors
RMA codes (in german language)
Philips capacitor
17.Sep.10 07:15
15 von 12472
Articles: 2327
Count of Thanks: 15
The letter stands in the place of the comma.
8E2 = 8,2pF
400 = 400pF
2K2 = 2200pF
47K = 47000pF etc. (K = Kilo/1000)
But where is the circuit and the model that you mention?
Please place the model in RM.org.
Regards WB.
Model is entered.
18.Sep.10 00:51
72 von 12472
Articles: 25
Count of Thanks: 16
Dennis Wesserling
Thank you, to all who responded, for your input.
Model Philips BX250B(00) has been entered into the site's archives.
added link
