Philips unknown
Philips unknown
28.Oct.06 23:53
Jose Vigil (RA)
Articles: 62
Count of Thanks: 5
Jose Vigil
Dear gentlemen.
I want to know the model or type of this philips radio.
It was made in Argentina.
Bands covered, BC only
Date of production is probably mid 30's.
Dial shows an scale in meters (200 to 550)
There is also blocks with tuning reference to local stations.
Valve lineup (as received)is CK1, CF3, CBC1, CL2, CY1 and C8 regulator.
The photo shows the set. The grillecloth is not original.
I have more photos.
Best regards, Jose
Estimados amigos.
Quisiera saber el numero de modelo de esta radio Philips fabricada en Argenina
Bandas cubiertas, solamente BC
El dial tiene una escala en metros (200 a 550)
Tambien tiene cuadritos con emisoras locales de la epoca de fabricacion
Las valvulas (como la recibi) son CK1, CF3, CBC1, CL2, CY1 y C8 reguladora.
La foto muestra el equipo, la tela de que cubre el parlante no es original.
Tengo mas fotos.
Cordiales saludo, Jose
Philips - 535U
29.Oct.06 01:26
Roy Johnson (GB)
Articles: 283
Count of Thanks: 6
Dear Jose
It looks like a 535U,   There is some information if you look in the radios section.
The valve line up is correct and also the case looks the same.
Regards,
Roy
philips 535a
29.Oct.06 10:31
Maitiu Standun (IRL)
Articles: 151
Count of Thanks: 5
Maitiu Standun
hello jose, ur set is indeed a mid 30s set , its the south american varient, its been featured on this forum quite recently , i remember well because of the two red spots inside the dial , if u search back through the arcives on this forum ull find it , or open the model [radio] tab and enter it into the form and u should get all the info necessary , im restoring a phillips 525a , which has an identical cabinet , but the dial and soround are slightl y different,   as is the valve line  up ,
best of luck with ur project  , regards maitiu.
unknown Philips
31.Oct.06 00:19
Jose Vigil (RA)
Articles: 62
Count of Thanks: 6
Jose Vigil
thanks Roy, I went to the model 535U, and yes, it looks very similar. Perhaps it is an argentine version of the dutch type.
It lacks the LW band. This band was never used into argentina.
Best regards, Jose
Unknown Philips
31.Oct.06 00:29
Jose Vigil (RA)
Articles: 62
Count of Thanks: 7
Jose Vigil
Hello Maitiu. Thanks for the advice. Actually I´ve put a thread for this set several months ago.
Unfortunatelly the tag with the type Nr. is worn and unreadeable.
Best regards, Jose
535u,
31.Oct.06 00:43
Articles: 151
Count of Thanks: 6
Maitiu Standun
hi jose , ur model must have been the one i saw, i remembered the red spot inside the dial, there is a dutch model identical except it has long wave , its known as 535a .. u can see the model if u click the radio tab on the main page of this forum and fill the model no in , regards maitiu.
