pilot: ; 205
Dieser Artikel betrifft das Modell: 205 76 tube (Pilot Electric Mfg. Co. (Radio Corp.); Brooklyn (NY))
pilot: ; 205
19.May.07 08:15
3234
To get optimum search I put the obviously identical models 205 (75 tube) and X205 together. Now both ways to search will arrive at the model "205 (X205)". And the model with 76 tube is also clearly defined.
To use early and late would not help. A collector looking for info in RM would never find such a hint on his radio. In our case here the tubes are unambiguous means to discriminate.
In addition "early" and "late" as found in some Sylvania Service notes are in doubt insofar, as both versions are noted for the same year 1936 (Riders vs. Machine Age).
Von Moderator abgeschlossen. Sie können u.U. über ihn weitere Antworten hinzufügen.
