blaupunkt: Polarity of choice
? blaupunkt: Polarity of choice
18.Jul.24 15:30
23
Ulf Olovson (S)
Articles: 4
Count of Thanks: 5
Hej
I have this Blaupunkt Frankfurt 7 630 640 000, C 3699841(1970), It says on the cover one can swap the polarity depending on what car one have. Where is this done in the radio?  I just can't find it.
On the top cover one can see VOLT(inprinted) but the pcb board sticking out at the back has minus on one side & plus on the other. I think it should say 6V resp 12V.
Any idees?
BR//Ulf , Stockholm
18.Jul.24 18:50
23 de 1101
Michael Watterson (IRL)
Articles: 1126
Count of Thanks: 4
Is that not a tab that pulls out?
The orientation sets -/+, if indeed the model is switchable at all.
I think only older models have the 6/12V (my grandfather still had a 6V Volkswagon Beetle in the early 1960s). It's a 1970 / 1971 model and by 1972 even reversible polarity was rare. It wasn't hard to reverse the polarity of some Fords with + earth to negative, that used a dynamo, by "flashing" the dynamo field windings.
The Frankfurt model name was used on different models from 1966 onward. Maybe 1969 was last 6V/12V model.
Most later 1970s Blaupunkt and probably all later years are - ground, +12V only, but if is changeable +/- the tab should pull out. On some models a - uppermost means negative earth/chassis and +12V supply.
19.Jul.24 05:09
60 de 1101
Ulf Olovson (S)
Articles: 4
Count of Thanks: 7
Thank you Michael
Yes, the tab that pulls out. It says - on one side & + on the other. On the lid its indicated Volt though. The text label on the lid indicates one can set polarity & voltage.
I have another radio where the tab says 6V resp 12 Volt, indicated on the lid is Volt.
However, now, I suspect the lid on the Frankfurt radio, could come from another radio.
Thanks
19.Jul.24 08:02
70 de 1101
Ulf Olovson (S)
Articles: 4
Count of Thanks: 5
