racal: RA-63 SSB Adaptor - Variants
Dieser Artikel betrifft das Modell: SSB Adaptor RA-63 (Racal Engineering / Instruments / Electronics Ltd., Bracknell)
01.Oct.06 00:17
2847
Variants of the RA-63 SSB Adaptor:
RA-63A: for use with receivers with 100 kHz IF out
RA-63B: for use with receivers with 100 kHz IF out, US type plugs and sockets
RA-63C: for use with receivers with 465 kHz IF out
RA-63D: for use with receivers with 100 kHz IF out, improved stability through
crystal controlled 82 kHz oscillator
RA-63E: for use with receivers with 455 kHz IF out
RA-63G: identical to RA-63A, improved stability through reinforced side panels
RA-63H: identical to RA-63B (US plugs / sockets), improved stability through reinforced side panels
RA-63K: identical to RA-63D, improved stability through reinforced side panels
RA-63L: identical to RA-63E (455 kHz IF), improved stability through reinforced side panels
RA-63M: identical to RA-63C (465 kHz IF), improved stability through reinforced side panels
