Radioactive Valve? Uranium Dioxide Tube EUV1
? Radioactive Valve? Uranium Dioxide Tube EUV1
29.May.21 00:08
119
Iordanis Smyrnis (GR)
Articles: 2
Count of Thanks: 5
I am in the procedure of trying to fix a friend's radio Kapsh Victoria from Austria.
Inside i found a weird tube like a light bulb and after using  a magnifying glass  i found out that it is a EU V1 tube.
An almost identical tube, the EUV , found on radiomuseum catalogue, says that it has Uranium Dioxide which is radioactive!!! Is this true?
Can someone indicate the use of it and if there is a way to avoid it in the radio and how?
Another Hazard in the radio is the metallic cover of the EU V1 tube with three stripes of what i believe is asbestos for heat dissipitation  !!!!
I cannot find a schematic of the radio to help me.
Tubes inside are the following EK2, ECH3, CBL1, CY1 &the EU V1.
Any idea, guidance, or suggestion is more than welcome!
30.May.21 21:11
119 from 1988
Articles: 1783
Count of Thanks: 3
Hello,
the EUVI – correctly written - can also be found in the radiomuseum catalogue,
About Urdox tubes please look at following links:
Are Urdox dangerous ?
Barretter-Urdox EUVI
comprehensive, in German, use a translator:
Heizkreisregelröhren: U, EW, EU, C
Best Regards,
31.May.21 23:15
198 from 1988
Andreas Steinmetz (D)
Articles: 744
Count of Thanks: 3
Hi Jacob,
sorry, your last link is faulty. Here is the correct link to the article "Heizkreisregelröhren: U, EW, EU, C".
Andreas
