rca-victor: RCA Model 62 tubes
This article refers to the model: 62 (RCA Victor (International), Montreal)
26.Dec.09 16:08
48
Alain Dufour (CDN)
Articles: 37
Count of Thanks: 26
Alain Dufour
Tubes for this radio are 5Y3GT; 6K6GT; 6AV6; 6BA6; 6BE6; 6BA6
add tubes to model page
27.Dec.09 08:48
48 de 3492
Martin Bösch (CH)
Articles: 612
Count of Thanks: 18
Martin Bösch
Dear Alain, please always use the link "Add information" and make a proposal to add the tubes into the rm.org database instead of just listing them in a forum entry,
please let me know, if You have problems fnding the correct link / procedure,
kind regards Martin Boesch
Adding info to a model
28.Dec.09 01:42
102 de 3492
Alain Dufour (CDN)
Articles: 37
Count of Thanks: 19
Alain Dufour
Hello Martin,
I used the first link "Add information" but I suppose you mean I should have used "Suggest a change" wich is to the far right. It seems more appropriate.
Alain
sorry, wrong link
28.Dec.09 08:16
116 de 3492
Martin Bösch (CH)
Articles: 612
Count of Thanks: 19
Martin Bösch
Hallo Alain, of course, You are right, You got the right link...
there is one little point, be become a perfect tubes uploader: please write the tubes from the antenna connector to the spaker and finally the rectifier tube, usually found from the left to right on the schematic.
I'm not a tubes expert, the 5Y3 is the rectifier tube.
There is only one rule from earlier days of rm.org database, when less space in the tubes list was available: the magic eye (if there is one) should be in fifth position in the list.
Kind regards and all the best for 2010
Martin
p.s. You can write in english or even en français, You might use the admin-en or admin-fr adresses too, if You have problem's with rm.org's website / database.
