Replace EY82 with EY80
Este artículo se refiere al componente: Ir a la válvula/semiconductor
? Replace EY82 with EY80
12.Apr.20 19:52
Joaquín Méndez (E)
Agradecimientos totales: 17
Could you use this EY80 valve (damper, booster, flyback diode on TV receivers) as a normal rectifier on a radio receiver, to replace an EY82, to get 180mA at 250v? Thank you.
12.Apr.20 20:36
8 de 2649
Moderador
Artículos: 1802
Agradecimientos totales: 10
Hello Joaquín,
yes, this should work. The EY80 can withstand a much higher peak inverse voltage as the EY82.
Best Regards,
Jacob
