sharp: Sharp UC-103
Este artículo se refiere al modelo: UC-103 (Sharp; Osaka)
? sharp: Sharp UC-103
16.Nov.23 21:21
Vicente Moncholi-Cebrian (E)
Artículos: 23
Agradecimientos totales: 17
I recently won an auction and now own this radio Sharp UC-103.
In the Radiomuseum list appear this radio but not schematics are present, with only one owner, Peter Spies.
In one of the photos I can see some documents glued to inside upper cabinet, so, I beg to Peter Spies if he can take a photo of those documents, because one of them is the schematics.
Y become veru grateful to Peter.
Thanks and regards.
Vicente Moncholi - Sevilla - Spain
sharp: Sharp UC-103
16.Nov.23 22:14
7 from 2125
Peter Spies (NL)
Artículos: 3
Agradecimientos totales: 8
Peter Spies
Dear Vicente,
I regret the Sharp UC-103 is no longer in my posession. I do not have any other pictures of its inside apart from what I published on Radiomuseum.org.
However, if you do a model search by tubes on Radiomuseum, quite a few Japanese radios pop up with the same tube line up, and WITH a schematic. For instance the Sharp UK-125, and Onkyo OS-155.
The Onkyo has a very similar look and feel to the Sharp, so hopefully its schematic will be helpful to you.
Best Regards, Peter
sharp: Sharp UC-103
16.Nov.23 22:15
7 from 2125
Eilert Menke (D)
Moderador
Artículos: 887
Agradecimientos totales: 11
sharp: Sharp UC-103
17.Nov.23 20:47
101 from 2125
Artículos: 23
Agradecimientos totales: 9
Hello Peter,
thanks a lot for your hints, I will check it.
The Onkyo seems very similar to Sharp, there is a difference on mains, the Sharp has an autotransformer to change from 110VAC and 220VAC but the Onkyo does not.
I will inform about.
Regards.
Vicente
