Siemens SRP4 - AEG A4 2F
? Siemens SRP4 - AEG A4 2F
05.Feb.12 12:43
166
Hernani Capela (P)
Articles: 61
Count of Thanks: 6
Hernani Capela
Hi
I bought this divice in a fair of antiques.
Is complete and works, but what will be its use? apparently it will be a test harness to electric motors or transformers. There is a schema embedded in the box.
Someone can give more info on this equipment?.
General photo attachment.
Best Regards
Hernani Capela
Measurements for telephone systems
15.Feb.12 10:16
166 von 3474
Officer
Articles: 5750
Count of Thanks: 6
Dear Hernani
Since this is a model made in Germany, I thought I will bring in your question in German - and indeed, I received an answer from Reiner Scholz:
"We need a good picture (frontal without flash) of the entire plate. There is some more details which could tell what it is. I believe it has something to do with telephone manufacturing or controlling."
My suggestion is that you create a new model page for AEG A4 2F (A42F)
as a measuring equipment (type). Then you load up some photos - also one frontal so that one can see all figures - besides the separate plate - all 933 pixels width.
We then might find out much more.
Operating notes
24.Feb.12 13:04
229 von 3474
Mark Hippenstiel (D)
Articles: 1192
Count of Thanks: 9
Mark Hippenstiel
Hello Hernani,
could you please also upload an image of the operating instructions / schematics that are attached to the lid?
Thank you.
Mark
Siemens SRP4
25.Feb.12 01:12
269 von 3474
Hernani Capela (P)
Articles: 61
Count of Thanks: 6
Hernani Capela
Dear Mark,
Could you please translate in English your opinion about SRP4.
The photo in not easy to take, it have a plastic to cover the drawing  and not clear. Is need  a makeup to all drawing  but  with time.
Best Regards
Hernani Capela
the maker is not AEG
25.Feb.12 15:06
307 von 3474
Articles: 1192
Count of Thanks: 6
Mark Hippenstiel
Dear Hernani,
as I have already posted on the German thread on this model:
My assumption is that we are dealing with a relay tester (Relaisprüfeinrichtung). Multiple sources that I found while searching the web point toward this being the meaning of the acronym SRP - though I am not sure, hence my pointing out that it is an assumption.
You can find the soures I found in the German post for this model.
Regarding the AEG label on the device, this is an inventory label and probably specifies the division (the printed part of the label, A4 2-F Zentralmontage - meaning central assembly) and the inventory number (Inv. Nr.). The whole of that information is not of any importance to the device itself other than in 'historic' respect. They form no part of the type designation, however "7F-4" does. We updated the model page accordingly.
Regards
Mark
Siemens SRP4
26.Feb.12 17:24
358 von 3474
Hernani Capela (P)
Articles: 61
Count of Thanks: 6
Hernani Capela
Siemens SRP4 – 7F-4
Dear´s Rmorg  Member’s
I made my homework
Follow the testing and analysis of SRP4 :
The equipment and legend
(See the Attachment file: "Legend" )
  • A - Input/output Main Power
  • B - Normally  Open  (NO) --» Power OFF
  • C - Output 0- 20,32,48,60 VAC max 25A
  • D - Input command -» Main power ON-»OFF
  • E - Output  110V AC “low power” Note*
  • F - Output  8VDC at +-100mA
  • D1-  Reference Input command D
  • G - Output 110VAC  2/5A
  • H - Contact Open /Close -» Main Power On/OFF
  • I  - Push bottom  Main Power ON
  • J - Push bottom  Main Power OFF
  • K - Main Power On remote (NO)
  • L -  Main Power OFF  remote (NC)
  • M -  Ammeter and scale 0-2,5/0-25A (meter C output)
  • N - Select Main Power 110-130 or 210-260 V  50/60Hz
  • P -  Polarity of Main Power
  • R - Rheostat  control current output C
Note* Measurement delay time to operate the relay in test?
Dear Mark,
Yes, I believe  the equipment is building in order  testing  relays , with some power  (500VA). Industrial use .
I read with more attention the inside drawing and have always an solenoid connect to the equipment, output C.
Yes, I believe  the equipment is made by Siemens Model SRP4 – 7F-4 , and use by AEG in the field .
I had power ON the equipment and confirm the good working condition, the output  (C) supply up to 25A AC with good control from Rheostat (R)
Best  Regards
Hernâni Capela
10.Apr.12 01:11
473 von 3474
Hernani Capela (P)
Articles: 61
Count of Thanks: 7
Hernani Capela
Hi,
In attachment the best possible photo of  drawing.
Best Rgards
H Capela
