tecsun: Tecsun R9702: PCB versions and parts
30.Aug.22 15:40
938
Jose Mesquita (P)
Articles: 111
Count of Thanks: 3
Jose Mesquita
The Tecsun R9702 uses two PCB assemblies:
  • Analog Receiver PCB, with 23 transistors and 2 IC's
  • Digital MCU PCB, with 9 transistors and 2 IC's
Radio PCB combo versions found so far:
Analog Receiver PCB Digital MCU PCB Components Interconnect RF IC Audio IC
R-9702V3 R&D ZXZ 5.25 R9702C-V9 2006.11.15 Mostly discrete Rainbow colored wires LA1827 CXA1622M
R-9702(D2111) V5 2013.06.25  R-9702B-V2 2011.05.30 Mostly SMD Gray flat cable (Y)D2111F CD1622CB
R-9702(D2111) V5 2013.06.25 ​Analog Receiver PCB main parts
  • IC3   (Y)D2111F, seems similar to TA2111F - FM/AM RF tuner
  • IC4   CD1622CB - Audio power amp, stereo on headphones, mono bridged on speaker
  • Q1    2SK436 FET - SW RF front-end
  • Q2, Q3   2SK436 FET - SW RF Balanced Mixer
  • Q10, Q8, Q6, Q11 S9018 - SW1/SW2 1st Local oscillator
  • Q4    S9018 - 1st IF 10700 kHz
  • CF4   SW 10.7S filter
  • CF2   FM 10.7S filter
  • CF3   AM 455J filter
  • Q12   S9018 AM 2nd local osc 10.245 kHz
  • CY1   10.245 MHz xtal
R-9702B-V2 2011.05.30 Digital MCU PCB main parts
  • IC1  CD3610CR MCU, it is a SC3610 on a 36-pin PCB holder - Frequency reading, Clock/Alarm, and LCD driver, installed under metal shield
  • IC2  74HC138 1-of-8 decoder - RF band selector
Other components
  • SP 16T57Z-2  Speaker  16 Ohm, 0.25 Watt, 57 mm diameeter
  • MW ANT  85mm long with 7x3mm cross section, with 34mm length litz coil
