telefunken: 776WK; Gross-Super - LW contacts on Wellenschalt
This article refers to the model: Gross-Super 776WK T776WK (Telefunken Deutschland (TFK), (Gesellschaft für drahtlose Telegraphie Telefunken mbH)
09.Jun.07 15:49
Dear colleagues,
I respectfully request to know if the schematic for this radio should depict the LW contacts on the Wave band switch. I have closely compared this schematic with the model Telefunken 876WK, and I realize they do not have to agree for obvious reasons.
Also, of great interest is the question as follows: If the very fine steel activation cable should break, could the switch then be rotated through a complete 360 degrees, and thus possibly be left in an "indeterminate setting"??
I have just completed a repair of this broken steel cable, and it appears as though this is a very real possibility - please comment.
One final question - Is the original DRALOWID part #7089 designed to be a combination "On-Off/Volume control"? There is a slight "spring action" in the shaft, but there is no detent for an On-Off function - volume control is fine.
Respectfully,
Robert
Respectfully,
Robert
'Switchable' coupling capacitors
04.Jul.08 02:05
Gentlemen,
This posting relates to servicing problems on my Telefunken model 776WK but is cross-referenced also to the models AEG 78WK and the Telefunken 876WK due to VERY common circuitry. . . . I also place a similar post to the TFK 776WK model.
While reviewing the complete schematics - and especially for the AM2 to AL4 audio coupling capacitors on the model AEG 78WK, and very similar circuits on the Telefunken 776WK and Telefunken 876WK - I noticed the switchable extra coupling capacitor installed on the AEG78 and the TFK 876WK - but not on the telefunken 776WK.
Was that perhaps an intentional circuit change, or an omission on the schematic of the 776WK.
There are also differences within the AL4 output (control grid g1 resistor ratings) on the respective models - from 100/.5M ohms to 1,000/.5M ohms
I had for a brief period of time reception of stations on the MW and KW bands although the alignment was off by approximately 60 to 70kHz. After replacing the BF2 transformer, and confirming continuity on both sides, now I am back to the "mute" radio. . .
I would be most appreciative if any member has had similar experiences and could provide some helpful hints!
NOTE:
All tubes have been replaced with new ones, EXCEPT the AB2 detector. . . .That tube has been ordered from a seller in Europe and will be installed within the next week or so.
Respectfully,
Robert
NOTE:
Respectfully,
Robert
