telefunken: Export; Gavotte 7
This article refers to the model: Gavotte 7 Export (Telefunken Deutschland (TFK), (Gesellschaft für drahtlose Telegraphie Telefunken mbH)
? telefunken: Export; Gavotte 7
15.Aug.12 15:59
28
Enrico Mercuri (I)
Count of Thanks: 10
Count of Thanks: 10
Is the FM band 88-108 Mhz (on the Telefunken Gavotte 7 Export model) or is it shorter, such as 88-101 Mhz?
Thanks for a kind reply.
Enrico.
Gavotte 7 Export
15.Aug.12 19:34
28 de 3482
This export version of the Gavotte 7 has an FM range from 87.5 to 100 MHz, which is also mentioned at the schematic:
The Telefunken Gavotte 7 Export [Licensed by Armstrong] covers 88 to 108 MHz, the dial and the schematic indicates it. This model was exported to the U.S.A.
The other ranges are identical, Special is Long Wave.
