realtone-j: Transistor replacement question
? realtone-j: Transistor replacement question
21.Apr.19 23:37
Richard Varner (USA)
Articles: 4
Count of Thanks: 23
Hello,
I've been troubleshooting a Realtone TR-970 and the MW oscillator is dead.
Fortunately, I have the excellent schematic and parts list.
The oscillator transistor tests as damage -- it's a 2SA153 PNP , according to the parts list, which matches the spec printed on the transistor.
According to the Radio Museum website this is a germanium diffused high-frequency transistor.
Question: Can I replace this PNP with a silicon 2N3906 PNP transistor intended for general purpose low-power amplifying, or do I need a replacement more specifically matched?
Thanks ...
22.Apr.19 00:28
4 von 3738
Hilmer Grunert (D)
Articles: 386
Count of Thanks: 21
Hilmer Grunert
Hello Richard,
no, that type doesn´t work for AM-Oszillator. 2SA153 works up to 60 MHz.
Comparison types are AF124-AF125-AF126 or AF200
many greetings
Hilmer
22.Apr.19 01:55
10 von 3738
Articles: 4
Count of Thanks: 14
Many thanks!
I now understand that an NTE 126 will also work.
With kind regards,
Richard
09.Jun.19 18:46
250 von 3738
Articles: 4
Count of Thanks: 23
Still working on the same radio.
I needed to replace the audio driver transistor, an NEC 2SB113 -- PNP germanium.
Can I replace with a general purpose silicon PNP 2N3906?
Thank you.
Richard
09.Jun.19 20:47
265 von 3738
Günther Stabe † 19.8.20 (D)
Articles: 377
Count of Thanks: 18
Hello Richard,
you may try to replace with a PNP silicon type - it might work. With a mA-meter to control the current (~ 10...20 mA) and with your ears to check the sound / distortion...
It's not easy to find a matching "old" germanium transistor for little money in the States, so try it.
Best regards,
Guenther
By the way: please scan and upload the schematic - other collectors in this world may be happy...
10.Jun.19 20:06
340 von 3738
Articles: 4
Count of Thanks: 16
Thank you.
I've attempted several times to upload but so far have not succeeded.
I will keep trying.
Best regards,
Richard
