unknown: Type M10-C3
26.Mar.09 20:50
Rolf Franke (CDN)
Articles: 13
Count of Thanks: 17
Rolf Franke
Hi,
just want to inform you that the FM band on this set extends from 88 to 108.
This should be corrected in the spec sheet.
Rolf Franke
Yes please ;-)
26.Mar.09 21:18
Officer
Articles: 5751
Count of Thanks: 13
Dear Rolf
Thank you for telling. Our system and organization is built in a way that each member can directly access the model and use the link in the linkbar below. For adding information or changing information it is the third link there.
Can you please try to add this information to the field "notes"?
Two model admins will then check. Please give them reasons - e.g. the source of your knowledge and everything will be fine.
Thank you for your activity.
