AZ41 (AZ41) pin assignment
This article refers to the component: To the tube/semiconductor
02.Nov.14 23:07
4864
I have just read the "warning" about pin assignment of this tube.
I have a couple of tubes both manufactured by Philips.
In the first tube, maybe older, pins 1 and 5 are connected to the tension spring of the filament, pins 3 and 4 are connected to the center of the filaments.
In the second tube, pins 1 and 2 are connected to one anode, pins 5 and 6 to the other, and 3 and 4 again to the center of the filament.
I have only one radio that employs this tube, but in case of replacement I need extra care to check the socket connections to avoid problems.
