dumont-la: Dumont 1120 clock radio Couplet failure
This article refers to the model: 1120 (DuMont Labs, Allen B., Inc.)
? dumont-la: Dumont 1120 clock radio Couplet failure
01.Oct.21 04:53
Jay Graven (USA)
Articles: 8
Count of Thanks: 4
I'm preparing to restore the circuit of a Dumont 1120.  I noticed that the measured resistances for couplet were far off.  The 470K resistor between pin 5 and pin7 measured 1.8M ohms.  The other 470K resistor between pin 6 and pin 4 measured 5.5M ohms.  And the 10Meg resistor between Pin 1 and Pin4 measured 16.5M ohms.
Is it common for these to fail?  I just had to rebuild one on a Sylvania R518 couplet.
Schematic included by DR
01.Oct.21 08:59
10 von 987
Torbjörn Forsman (S)
Articles: 195
Count of Thanks: 5
Yes, it is very common that cheap carbon composition resistors become unreliable when aging. This is particularly true for resistors that have been subjected to DC current for a long time (for example, screen grid resistors and anode loading resistors in tube technology).
It is also common that a carbon composition resistor that has been used for DC for a long time, becomes unlinear which can cause strange phenomena (for instance, distortion in an AF amplifier). A simple way of checking this is to measure the resistance twice and change polarity of the meter between measurements. If the resistor does not show the same resistance with both polarities, it should be regarded as suspect even if both measurements are within tolerance.
01.Oct.21 19:08
47 von 987
Jay Graven (USA)
Articles: 8
Count of Thanks: 6
Further review of the schematic from Rider, I now believe the Dumont Clock radio is a model 1140 or 1150 and not the 1120.
