ECL 11 AND EL 11 TUBES
? ECL 11 AND EL 11 TUBES
06.Jun.17 21:26
54
Aras Mahmood (S)
Articles: 19
Count of Thanks: 8
Aras Mahmood
Hi every one
i just have a question(which might sound dumb)
i have a GRAETZ -51W radio ,it usese an EL11  as an ouput tube,,so, can i use ECL11 instead.
if not ,can anyone explain why please..
 much obliged
 Aras
07.Jun.17 11:16
54 de 3094
Michael Watterson (IRL)
Articles: 1109
Count of Thanks: 8
You'd need a base adaptor (less nasty than re-wiring the base as they are not pin compatible). I'd have been surprised if ECL11 is cheaper / more available.
The Octal EL33 (= EL3NG) and P8 base EL3N (same order of connections as Y8) are essentially the EL11. The EL11 is a Y8 base. Often the base on dead tube and good tube can be loosened by soaking in warm water (the glue is often wood powder or flour mixed with varnish). Or you can buy or make an adaptor.
I'd leave the radio unchanged and either swap base on tube or use an adaptor. There are other tubes that will work on same g1 and g2 bias.
NOS and used EL 11 TUBES
07.Jun.17 14:59
75 de 3094
Heribert Jung (D)
Articles: 1019
Count of Thanks: 6
Hi Aras,
I have more than 20 used EL11 and 2 NOS EL11. If you like to get one, I can test them with my Funke W20.
You may contact me by mail.
Heribert Jung
08.Jun.17 13:29
151 de 3094
Aras Mahmood (S)
Articles: 19
Count of Thanks: 9
Aras Mahmood
thank you very much for your help gentlemen
Mr. Jung i have send an e-mail to you regarding the cost of the EL11
thanks a lot
Aras
15.Jul.17 22:55
415 de 3094
Heribert Jung (D)
Articles: 1019
Count of Thanks: 7
Hi Aras,
you got the tubes and I got the money. I hope the tubes work well in your radio.
Greetings,
Heribert
