ever: Old cover solves Alkaline Problem
This article refers to the model: Dry Cell Battery U2 (Ever Ready Co. (GB) Ltd.; London)
18.Dec.12 03:39
76
Michael Watterson (IRL)
Articles: 1144
Count of Thanks: 10
The Zinc Carbon uses a Zinc case as the negative. The positive is a carbon rod with a cap.
On the Alkaline cells the negative is a disc and the "cap" (positive) is a moulded part of the can.
On modern stuff the battery holder is plastic, so no problems. But older stuff is metal and the Alkaline cell may have only a thin foil covering insulating the positive can from the chassis connected to negative. The foil is easily torn or scraped and then the battery is shorted out. This is particularly a problem on the Philips Annette and similar valve radios with a cut out in the metal chassis for the "D" cell. Here is my solution:
A vintage battery label, two layers of paper and outer clear parcel tape
I had this (actually it was very poor and wrong size, so I edited it a lot):
eveready 1950s D cell sleeve
Don't use this, it's the wrong size, use full size in Gallery
And a photo of an old Ever Ready U2. I copy / pasted the logo from a B114 and typed/drew the rest
Download the full size from the Model photo Gallery (On Go to Model link if you can't see it)
Print at 150dpi gives enough ease for thin card, or else use "Pritt/UHU" Stick glue and place while wet so outer slides on inner to avoid wrinkle.
Glue tab on battery (maybe peel off film).
top & bottom should overlap ends, put a little glue around and then fold a small part of overlap rotating the cell each time.
Don't block safety vents on bottom with glue.
Finally cover with clear parcel tape, clear film, or varnish to your choice. A good  Zinc Carbon D cell at low current (50mA series chain) may be 6500mAH. Modern ones with two plastic bungs are about 5000mAH or less. At low current a Zinc Chloride is little improvement. An Alkaline D cell may give 12000mAH or more depending on load., about 20% more than an F Cell.
This is a mk1, so the spacing may not be 100% correct. but it looks nicer than brown tape or blank card.
All my designs are deliberately faded to save ink and also not be mistaken for real. You can adjust gamma to make the blue darker to have it more realistic.
Over here I have uploaded a  cover for Pertrix Nr 231 for the German Sets :-) which I think is equivalent to a U2 or D Cell.
(P.S. if you don't see the covers, then the article is only just written and the images are not yet approved)
Example
19.Dec.12 10:31
76 von 3890
Articles: 1144
Count of Thanks: 19
Here is example of Philips Annette PSU chassis, the frame cuts film and shorts out Alkaline from Tesco as they have very thin flim insulation and the can is part of +ve top cap
Tesco battery covered in Pertrix 231 sleeve.
Here is Marconi T24DAB with 5 plastic film insulated Zinc Carbon cells. They can touch at top of can (which is -V).
