graetz: 817; Musica |
Mario Coelho ![]() Schemi: 409 Foto: 1030 27.Aug.03 12:19 Nr. ringraziamenti: 4 |
Rispondi | Devi effettuare l'accesso (Ospite) 1
I would like to aid this information to the model: All those three speakers are dynamic. This radio has stereo facility and has also two options more (two push buttons else) "R-Klg." and "MA". The fist gives a wide space sound. The other cuts the magic eye facility and nothing more happens I can notice.. Mário |
Hans Kamann ![]() Schemi: 79 Foto: 57 27.Aug.03 16:11 Nr. ringraziamenti: 4 |
Rispondi | Devi effettuare l'accesso (Ospite) 2
Dear Mario, apparently you were able to finish repair. Congratulations ! The Button "R-Klg." stands for "Raumklang" and enables exactly what you described. The other, "MA" stands for "Magisches Auge" and simply switches off the Magic Eye. I´ve seen other radios with the same feature, my guess is the manufacturers knew about the limited life time of the magic eye valves. Questo articolo è stato modificato il 28.Aug.03 22:15 da Hans Kamann . |
Ernst Erb ![]()
Funzionario
CH Articoli: 5700 Schemi: 13756 Foto: 31072 27.Aug.03 19:53 Nr. ringraziamenti: 7 |
Rispondi | Devi effettuare l'accesso (Ospite) 3
Dear Mario and Hans Kamann We actually would like that there are more languages used and that somebody starts the English part all right. Therefore: Is it possible that you copy your text and post it again the same way - but with the language selection? After having done this I woul like a post here that I can delete this one ... Maybe that does Hans Karmann because then it is clear that both parts have been mooved. Thanks for your help to get the English start all right. I will now select the e-mail information about a new post - and will be informed automatically - as can do everybody when interested in an article. |
