grundig: Grundig Satellit 650 S-Meter Problem
? grundig: Grundig Satellit 650 S-Meter Problem
08.May.18 20:46
135
Fred Eddie-Quartey (USA)
Articles: 7
Count of Thanks: 33
Hello All,
I have just acquired a Grundig Satellit 650 International and all functions seem to work very well, with the exception of the s-meter.  The s-meter does not seem to register any signal on any wave band, regardless of the strength of the in-coming stations.  I have tested with both the internal antenna and an external one but there is barely any movement from the needle.
I did notice that when I am listening to any of the AM wavebands, and I have MGC switched on full, the s-meter deflets all the way to 10.  If I tune across the band, the meter moves back and forth between 0 and 10 as noise or weak/strong stations is received.  On FM it barely moves beyond 0, if at all.
Any clues as to what is wrong?
I appreaciate your advice/assistance.
Thanks,
Fred.
14.May.18 00:33
135 de 4644
Articles: 7
Count of Thanks: 28
Hello,
After a little research, I was able to find a service manual and found the trimmer pots for adjusting the s-meter on AM and FM.  Now the meter works as it should!  Almost.  I noticed that sometimes, if I change wave bands, the meter stops working.  Other times, it works fine.  Still puzzled as to what is going on.
Thanks,
Fred.
28.Sep.20 12:30
779 de 4644
Steve Rowley (GB)
Articles: 18
Count of Thanks: 22
Mine was like that. It was a faulty meter. I had to find another.
08.Mar.22 18:02
1336 de 4644
Martin Bösch (CH)
Articles: 618
Count of Thanks: 23
Martin Bösch
IF you switch to MGC (Manual Gain Control), it is the usual behaviour in shortwave receivers that the S Meter deflects to full, if you decrease the RF Gain.
So I think, there might be a problem with the signal from the AGC amplifier fed to the S meter driver amplifier. But I'm not an electronics expert...
At least, if you switch to MGC and the S meter moves to full deflection, the instrument itself is probably working.
Only my five cents, kind regards Martin
