hot trafo
? hot trafo
28.Nov.13 21:06
29
şaban özyazgan (TR)
Articles: 10
Count of Thanks: 4
Hi,I am first on this forum,and a new restorer.I have a schaub lorenz goldy 3133 radio,my problem the radio is no working , only it has flament lights.another problem, trafo is very hot, I have replacemend C98 and C99(4700pf 1600V), after I have measuremend voltages on EZ80 tube and results;
pin1  zero VAC
pin7 235VAC
pin3 zero VDC
interesting thing is that;when EZ80 on socket,pin1 connect to ground but when there is no on socket, it is no connect to ground. EZ 80 is faulty? or trafo
Measure with radio unplugged first
29.Nov.13 00:40
29 de 4341
Michael Watterson (IRL)
Articles: 1144
Count of Thanks: 2
With no EZ80 plugged in and Radio not plugged in:
A) Resistance pin 1 to chassis / negative common
B) Resistance pin 7 to chassis / negative common
C) Resistance pin 1 to pin 7
C should equal A + B
A & B should not quite match, but be similar (same number of turns, but usually one winding is inside the other, so less length of wire.
If one measurement is A or B is much less then there is a short. If one is very high, it's open.
Remove ALL valves (tubes) and lamps.
Plug in to Electricity and see if Transformer gets hot. (slightly warm is OK). If hot, it's got a short and faulty
hot trafo
29.Nov.13 16:39
76 de 4341
şaban özyazgan (TR)
Articles: 10
Count of Thanks: 4
I measuremend resistance and the results;
pin1 to chassis 213 ohm
pin7 to chassis 224 ohm
pin1 to pin7  437 ohm
VDE and Transformer Heat
29.Nov.13 17:03
81 de 4341
Articles: 2129
Count of Thanks: 4
Hello Mr. Watterson.
Maybe this give you an additional information. Post 13
regards from  HansM. Knoll
Thanks
29.Nov.13 17:28
97 de 4341
Articles: 1144
Count of Thanks: 2
Thanks Hans!
However şaban özyazgan
The resistances sounds as expected. The small difference is the difference in length of wire for same number of turns but outer vs inner layers. Of course a single shorted turn will not show up in a resistance check. That is why Part 2 of test is to see temperature rise with NOTHING taking current.
So now power the transformer WITH NO tubes or lamps or EZ80 connected. No load at all.
Then report how hot does it get in degrees C (with no load at all it should not be too hot to touch).
However make sure you are on the correct mains tap and your line voltage isn't too high, because even 10% too high the core can be close to saturating and iron losses rise rapidly.
If the transformer has a shorted turn it will get very hot and may eventually smoke. If the transformer FED WITH CORRECT volltage and no load (not even bulbs or filaments) only gets warm but you can touch it without burning, then the fault is elsewhere, not the transformer.
hot trafo
29.Nov.13 19:10
115 de 4341
şaban özyazgan (TR)
Articles: 10
Count of Thanks: 4
Mr.Watterson
I checked your step 2 and There is no much hot on the trafo and no smoke.
Good
29.Nov.13 19:23
119 de 4341
Articles: 1144
Count of Thanks: 2
The problem is less expensive. It's not the Transformer.
Make sure the HT electrolytic capacitors are OK. I use a current limited bench PSU. So witn no EZ80 and power off measure HT current as you increase up to 30V. If Current is under a couple of mA, then perhaps you have a faulty EZ80 or wiring. The EZ80 anodes should only connect to transformer. The Cathode to + of 1st HT Electrolytic.  The transformer centre tap to the Electrolytic - or case etc.
A pair of 1N4007 each with 47 Ohms in series can be temporarily used instead of an EZ80 till you get a replacement. This does stress the Electrolytics more as the voltage is very high instantly until the output tube  is running. Do make sure the capacitor feeding the output EL84 grid is not leaky or the EL84 takes too much power and transformer is hot also EZ80 gets damaged.
hot trafo
29.Nov.13 20:15
126 de 4341
şaban özyazgan (TR)
Articles: 10
Count of Thanks: 4
Mr.Watterson,
tomorrow I will try your recomments.thanks
hot trafo
01.Dec.13 11:24
181 de 4341
şaban özyazgan (TR)
Articles: 10
Count of Thanks: 3
Hi,Mr. Watterson
I have replacemend electrolitic capacitors and EZ80 tube and just the radio is working and no hot trafo.thanks for all of your interests but now I have a new problem; I need a schema for dial scala cord,because the dial cord is missing for LW,MW,Sw bands.
Drive Cord
01.Dec.13 14:08
196 de 4341
Articles: 1144
Count of Thanks: 3
Go to model (this all should be under the model)
Scroll down to about 4th last photo of the front view of chassis  and drive cord.
General Tips:
  1. Make tuning capacitor fully closed / meshed.
  2. Check which is Low frequency  / big wavelength of scale.
  3. About 2.5 turns round drive spindle with tuning knob.
  4. Arrange direction of turns on drive knob shaft such that clockwise moves scale pointer to left (anti-clockwise to right).
  5. Cord on more than 180 degrees of drum such that pulling it will open tuning capacitor.
