telefunken: Info request about Telefunken 770 wkk device 15.03.2021
15.Mar.21 10:00
20
Ion Carabas (RO)
Articles: 40
Count of Thanks: 5
Ion Carabas
Dear Mr. Tomasz, I measured the voltage on the detection and it is -1.0 volts, very small. As you can see from the photo below, I changed almost all the variable capacities in the channel block. The original ones no longer work after 83 years from manufacture and we replaced them with variable air capacities. You are right that the oscillator circuits and input circuits were not tuned. As soon as I will tunned them, I will keep you informed if the magic eye works normally. Attachments:
15.Mar.21 11:08
20 de 1213
Eilert Menke (D)
Articles: 880
Count of Thanks: 5
I had already pointed out here that you should respond in the original thread and not open a new thread. Now, in turn, you do exactly this here again. Is that to difficult to understand?
Thread locked Thread closed by a moderator. But replies can be made through a moderator.
