metz: 409/3D;
This article refers to the model: 409/3D Inland (Metz Transformatoren- und Apparatefabrik (ex TAM), Fürth)
metz: 409/3D;
28.Sep.05 06:55
2619
Does anybody have information about this model?
After resurecting an American version of this radio, I am amazed to find that it came with a partial circuit board (just the amp section with tube sockets in it), bipolar electrolytic capactors on the speakers, use of of an EF86 in the amp section, to just name a few things.
It does lack the build quality like its competitors, SABA, Telefunken, and Grundig, but the big speaker and the push pull amp, makes this radio a "screamer"!
Since there is no schematic on RMorg. , I had to sort of figure out what's going on, by using the listed schematics for the 408/3D and 410/3D models.
The only major flaw is, that they placed the self biasing resistor directly on the circuit board(rated at 1 watt). Of coarse, the resistor was open, and needed to be replaced. When I recapped the board, I placed a 5 watt sandstone resistor seperated from the board for heat disipation.
Is there any advice someone can give regarding the tuner/clutch mechanism?
Thank you
Omer
Thank you
Omer
