panasonic: National T-100MD - Transistor configuration identical to T-1
This article refers to the model: World-Wide T-100MD (Panasonic, Matsushita, National ナショナル (also tubes); Osaka)
06.Jun.21 15:00
881
According the the paper label glued to the inside of the battery compartment door of the T-100MD model, the transistor configuration is the same as seen on the T-100Y model variant. Here is the listing:
- TR1 2SA241 FM RF AMP
- TR2 2SA71 FM MIX
- TR3 2SA71 FM OSC
- TR4 2SA70 AM OSC
- TR5 2SA70 FM 1ST IF & AM MIX
- TR6 2SA70 FM 2ND IF & AM 1ST IF
- TR7 2SA70 FM 3RD IF & AM 2ND IF
- TR8 2SB173 1ST AF
- TR9 2SB173 2ND AF
- TR10 2SB175 3RD AF
- TR11 2SB324 OUTPUT
- TR12 2SB324 OUTPUT
We would need to find a circuit diagram for the T-100MD to know about the rest of the semiconductors in use (diodes).
