nordmende: speakers wire connections
? nordmende: speakers wire connections
04.Jan.14 22:51
40
Bruno Gandolfo-Canepa (RCH)
Articles: 121
Count of Thanks: 20
Respected members.
I am asking specially to the Tannhäuser 57 radio owners, about the speaker's wires connection over the output trafo.
I am restoring a set who arrived with the six wires unattached to the five pins plate over the output trafo.
I have not been able to properly identify  the pins where they need to be soldered again. One of the speakers, the electrostatic tweeter, has 192 volts to operate. A wrong connection can burn the other speakers.
I will be very thanked if a kind member can send a diagram o photos showing the speaker's wire connections.
Thanks in advance,
Bruno.
Tannhäuser 57 speakers wire connections
05.Jan.14 11:08
40 from 3252
Articles: 2320
Count of Thanks: 17
Hallo Bruno,
I have given the diagram with the output transformer to the model.
I hope the colors of the jacks to help you.
The electrostatic tweeter is not connected to the transformer.
The remaining connections you see in the wiring diagram.
Regards WB.
alignment instructions
05.Jan.14 16:32
62 from 3252
Articles: 121
Count of Thanks: 21
Hello Wolfgang,
Thank you so very much for the quick answer. With the color code secondary windings it will be easy to solve the puzzle.
Now I saw the  alignment instruction. l it will be very usefull for me also.
Thank you again,
Bruno.
