philips: 661U (661 U);
This article refers to the model: 661U (Philips Belgium (Belgien))
? philips: 661U (661 U);
03.Apr.09 15:39
This Philips 661U set was made in Belgium (Philips Leuven factory), see the Philips model plate.
It was sold in Belgium too, by SBR, see the GIRA notification and the SBR-SEM licence, both will be found at the back panel.
For what reason this model is linked to Philips Deutschland?
Suggest change
03.Apr.09 17:54
Hallo Mr. Hupse,
when you find such a mistake you can make a "Suggest change" on the model side.
For this model I did it for you.
Regards WB.
