sachsenwe2: 502Wn; Olympia
? sachsenwe2: 502Wn; Olympia
23.May.12 09:53
35
Roberto Pietrafesa (I)
Articles: 3
Count of Thanks: 10
Roberto Pietrafesa
Dear all, good morning first of all.
I bought an old OLYMPIA 502 Wn that has not the loudspeaker (it was removed).
I bought on ebay an old electrodynamic loudspeaker, but it is not good.
Because of the rush, which is a bad counselor, I discover that this is not the right piece I need, since the diameter is bigger than I need to fit into Olympia 502 Wn.
So, now, aware that I have not had a good reputation making this action, I'm kindly ask you if you can suggest me where may I buy a right electrodynamic loudspeaker for this radio.
Thank you for your help. I appreciate it very much.
Sincerely,
Roberto.
Actually offered
23.May.12 22:06
35 from 2582
Reiner Scholz (D)
Articles: 247
Count of Thanks: 12
Reiner Scholz
Most likely this one will fit into your 502 Wn. At least it´s a Sachsenwerk speaker. Ask seller for max diameter of speaker chassis first. Screw holes are located on a diameter of 19 cm.
Reiner
