siemens: 25WLK (25 WLK);
This article refers to the model: 25WLK (Siemens (& Halske, -Schuckert Werke SSW, Electrogeräte); Berlin, München)
04.Jan.10 16:51
3413
I think this model still takes SW range! If aerial-switch (33) is set into the last (9th) position on the right, the radio needs aerial to the 1. or 2. SW input for receiving, and lots of stations come. In case of other positions, SW inputs are not active. Otherwise, aerial connected to the MW input is not enough for SW receiving, aerial connected to the SW inputs does not support MW receiving... On the other hand, I do not know, why there are two SW inputs.
By the way, scaling includes 18-55 m, 125-400 m and 500-1500 m ranges.To thank the Author because you find the post helpful or well done.
