philips: SPECIFICATIONS
This article refers to the model: Beethoven 02RH805 (RH805) (Philips Australia)
25.May.21 03:20
2615
Gary Cowans (AUS)
Articles: 111
Count of Thanks: 9
Gary Cowans
SPECIFICATIONS
Record Player:
Wow & Flutter:   <0.2%
Rumble (DIN):   -55 dB
Stylus:               15 uM Diamond
Compliance:       >6.5 mm/N
Headphones
Impedance:        4- 15 Ω
Tape Recorder
Input:                    1 V into 50 k Ω
Input:                    100 mV at 7.5 kΩ
Microphone
Input:                    1 mV into 50 kΩ
Power Consumption
                             100 watts
Amplifier
Load Impedance
                             Loudspeaker:    3.5, 8 or 15 Ω
 Power Rating 8 Ω
                             90 watts Total peak music
                             18 watts per channel (RMS) 0.5% THD
Freq. Resp.:         20 Hz – 20 kHz ±3 dB
Bass control:         ±15 dB at 100 Hz
Treble Control:      ±15 dB at 10 kHz
Multi-Band Tuner
Freq. Range
MW:                      525-1605 kHz
SW1:                    10.0 – 26.7 MHz
SW2:                     3.85 – 10.2 MHz
SW3:                     1.6 – 4.2 MHz
Bandwidth
-6 dB:                    6.75 ±0.75 KHz
-20 dB:                  12.5 ±1.0 KHz
Signal to noise ratio
                                >18 dB for 300 uV/M
