telefunken: 55; Gavotte MW(AM) Ferrite Core Antenna
Moderatori:
Forum » Radio e altri tipi di apparecchi (dalla fisica alle TV) » MODELLI NEL SITO » telefunken: 55; Gavotte MW(AM) Ferrite Core Antenna
Omer Suleimanagich
Omer Suleimanagich
USA  Articoli: 429
Schemi: 3
Foto: 56
15.Jun.08 08:03
Nr. ringraziamenti: 6
Does anyone know if this model came with a ferrite core antenna(built in), or only uses an external MW antenna?
The Gavotte 7, has a built in antenna.
Questo articolo è stato modificato il 15.Jun.08 08:25 da Omer Suleimanagich .
Redattore
D  Articoli: 2132
Schemi: 159
Foto: 102
15.Jun.08 11:40
Hello Omer.
A view to the inner Part of this Radio ( US Version)  and the part of the Diagramm, say. no, they have not a Ferritantenna.
Only long wire is províde.
regards knoll
Questo articolo è stato modificato il 15.Jun.08 11:45 da Hans M. Knoll .
Omer Suleimanagich
Omer Suleimanagich
USA  Articoli: 429
Schemi: 3
Foto: 56
16.Jun.08 05:18
Nr. ringraziamenti: 10
Rispondi  |  Devi effettuare l'accesso (Ospite)   3
Thank you Hans for the quick reply!
I suspected that this model  requires an external antenna, but was not sure, since other manufacturers with competative models of this vintage provided ferrite antennas.
I came to the conclusion, that the Gavotte 7, is probably the best model of this model series, being that it comes with internal MW and UKW(FM) antennas, bigger wooden case, uses an EL 84, and has a larger  speaker,  a long with two electrostatic speakers
Questo articolo è stato modificato il 16.Jun.08 07:08 da Omer Suleimanagich .
