telefunken: Telefunken Dacapo 9 Export - electrolytic replacement
This article refers to the model: Dacapo 9 Export (Telefunken Deutschland (TFK), (Gesellschaft für drahtlose Telegraphie Telefunken mbH)
? telefunken: Telefunken Dacapo 9 Export - electrolytic replacement
15.Aug.12 21:30
42
Has anyone replaced the ratio detector electrolytic on this model? It appears to be contained within a screening can surrounding the EABC valve and containing the demodulator inductors. Does the top of the can lift off without desoldering everything from below? Is it acceptable to leave this original component and simply replace the accessible electrolytics?
Thank you.
Give a look here
16.Aug.12 19:23
42 von 2795
Dear Steve,
if the old capacitor is not shorted, you can add a new one outside the discrimainator subassembly. Give a look at this article from Bernhard Nagel.
