Which tube is this
? Which tube is this
04.Jun.17 13:56
Nicolaas van Dijk (CR)
Articles: 41
Count of Thanks: 25
Nicolaas van Dijk
I have two tubes that are very similar to the ECC8100, but the base with the same dimensions as the noval, has 10 pins instead of 9. Looking inside, the connections of the first section is the same as the ECC8100. I can´t read the number anymore. It is almost sure the same internal systemm as the ECC8100
Anyone has an idea what tube this is?
ECC2000 ???
04.Jun.17 14:25
11 from 2509
Giovanni Cucuzzella (D)
Articles: 517
Count of Thanks: 24
Hello Nicolaas van Dijk,
maybe your tube is an ECC2000
Best regards
Giovanni Cucuzzella
ECC2000 ???
04.Jun.17 18:14
31 from 2509
Articles: 41
Count of Thanks: 19
Nicolaas van Dijk
Thank you very much Giovani, I am sure it is. The connections and the picture are the same. It is a pitty I can´t test, my tube tester doesn´t have this base
Kind regards
Nico
