Help for identification of radio console
? Help for identification of radio console
Goor evening radio lovers,
who can help in the identification of this radio console?
Th only tube with readable type number is the rectidier PV495
Thank you
Attachments:To thank the Author because you find the post helpful or well done.
Hello, What I see so far is your console looks like a radio from England made in the 30's or 40's. But more pictures are needed especially the rear part of the radio and a close picture of the dial. Also look for any labels or numbers stamped on the chassis or on the inside of the cabinet. If there is a back cover there should be a license or tax number if it is a British radiio. Another clue would be the plug for the power cord. English radios ran on 220-240 volts. Hope this helps
Schaub Bristol W
Most probably your console radio is this model: Schaub Bristol W from 1931/32. A similar model can be found here: Windsor W, which has a record player in the top.
Please load your pictures in high resolution to Bristol W since most of the present pictures there are of bad quality or too small.
Thank you.
