stromberg: name of screws for front panel
? stromberg: name of screws for front panel
04.Aug.20 19:52
26
Wolfram Zylka (D)
Articles: 456
Count of Thanks: 7
Wolfram Zylka
I am looking for the screws that fix the front panel for the device Does anyone know the exact name of these screws Thanks for your support
Best Wishes
Wolfram
05.Aug.20 02:01
26 from 1364
Lindsay Shepherd (AUS)
Articles: 13
Count of Thanks: 11
They are Round Head slot wood screws ( brass or stainless steel is best) select the correct size.
regards
Lindsay Shepherd
05.Aug.20 13:11
53 from 1364
Wolfram Zylka (D)
Articles: 456
Count of Thanks: 7
Wolfram Zylka
Thank you very much for your comment
In this case, the screws are fitted with a metal threat Enclose I made a sketch
In Metric measurements it would be not a problem to identify.
I like to find out the right name for it screw with the American Inch measurement
05.Aug.20 18:03
70 from 1364
Rolf Beckers (D)
Articles: 220
Count of Thanks: 6
Rolf Beckers
Hello,
These are metric lens-senkhead screws or in German Linsen-Senkkopf-Schrauben.
Regards,
Rolf
05.Aug.20 20:13
85 from 1364
Wolfram Zylka (D)
Articles: 456
Count of Thanks: 5
Wolfram Zylka
Thank you very much
Unfortunately the threat is not metric
I like to keep in original condition  and would
like to bye those screws.
But I don’t know what shall I look for
Regards Wolfram
06.Aug.20 04:21
130 from 1364
Mark Hippenstiel (D)
Articles: 1192
Count of Thanks: 5
Mark Hippenstiel
The Biritsh standard that can be found on some old UK devices would be Whitworth aka BSW British Standard Whitworth, or BSF British Standard Fine.
In America, the corresponding standard is UNF (see Wikipedia) but the manufacturer might have used something else for this model at that time.
The shape is called oval or raised head (in the UK "raised countersunk").
You're probably looking at a #6-40 or #8-36 screw, depending on accuracy of measurements.
Your best bet is to send a sample to a seller to make sure you buy something fitting -- unless you can reliably determine the threads per inch and pitch.
Hope that helps, and good luck,
Mark
06.Aug.20 12:21
163 from 1364
Wolfram Zylka (D)
Articles: 456
Count of Thanks: 5
Wolfram Zylka
Hello Mark
Thanks a lot for your detailed information.
I measured the screw carefully
It should be it one :
8-32 X 1 Inch Raised Slotted Countersunk Screw
Now I’m going to find a supplier
Best regards from Ireland
Wolfram
stromberg: screws for front panel
15.Nov.21 13:22
417 from 1364
Wolfram Zylka (D)
Articles: 456
Count of Thanks: 6
Wolfram Zylka
I have done the screw procurement. With success. I ordered suitable screws from Accu in Great Britain and received them after 4 days. Enclosed the data of the order process If any of our members are looking for screws for English or American radios: Based on good experience, I can recommend this supplier
Best regards
Wolfram
Accu
Hagg Wood Stone Quarry
Huddersfield, HD9 6PW
United Kingdom
tel: +44 (0) 1484 937010
fax: +44 (0) 1484 937020
e-mail: sales@accu.co.uk
website: www accu.co.uk
Accu Limited
Registered in Company No: VAT No: GB136780105
SFRK-8-32-1-A2 8-32 x 1 inch Raised Slotted Countersunk Screws (ANSI B18.6.3) - Stainless
Steel (A2)
Price   €  0.41 x 8 = € 3.28
