saba: 11 Stereo; Freudenstadt 11-Stereo International
This article refers to the model: Freudenstadt 11 Stereo (SABA; Villingen)
26.Sep.05 00:34
Robert Sarbell † 22.3.22 (USA)
Articles: 358
Count of Thanks: 18
Greetings Gentlemen,
Does any member know if the chassis of the "Freudenstadt Stereo 11 International" variant has the 7-pin socket or the 9-pin socket to receive the optional FM Stereo decoder?
Respectfully,
Robert Sarbell
MPX Adapter?
26.Sep.05 06:07
Articles: 2120
Count of Thanks: 8
Hello Mr. Sarbell,
Freudenstadt 200 ( 11 int) use the 7 pin Adaptersocket,  its a tube_adapter (ECC82, ECF80)
see here:
http://www.radiomuseum.org/forum/saba_multiplex_adapter_12_und_weitere_stereo_decoder.html
and than:
http://www.radiomuseum.org/r/saba_stereo_decoder_ei_usi_14.html
Regards Hans M.Knoll
Substitute adapter ??
26.Sep.05 17:19
Articles: 358
Count of Thanks: 13
Good afternoon Herr Knoll,
Thank you so much for your help with the references. Presently, I do not have the Saba mpx adapter 12; but I have a functional Telefunken MPX-adapter which I have considered to use as "suitable replacement"- it uses the ECF80 and ECC808 tubes.
The Telefunken adapter also uses the 7-pin socket; however, the "stereo indicator lamp" is activated through an additional transistor, and is placed on a small printed circuit board with the EM84 tuning indicator. The adapter also has a short, shielded 2-wire cable that connects to the "stereo indicator lamp".
Respectfully,
Robert Sarbell
